1 - 11 of 11 Posts
Hello. I recently decided to go SLI. I already have a new mobo and my second card is on the way. The only other problem that I know of is the PSU. Does anyone know how I can find out what PSU I'm gonna need for my new rig? I think XFX recommended 650 or something as a minimum for one of my cards. Any responses are greatly appreciated. Thank you.
What is the brand and model of the current one? If it's good quality it's fine, if it's some cheap junk then you should replace it with something like a Corsair TX series PSU at least.
A Corsair TX 750 or HX750 or above would be plenty. A TX650 probably also would, but then you would need molex-pci-e adapters for the second card, so I would pay the extra $10-15 for the 750w model. The TX PSUs are non-modular, the HX PSUs are modular and are also higher-quality. I don't know if you care about modular cables (I don't), but if you do, you can't go wrong with the HX750.
Super Moderator
Yup, it can even handle 3 easily if you use adapters.
Super Moderator
You shouldn't have to unless you find out the hard way it's a crappy unit.
Again: What's the brand and model of the 730W?
Oh yeah, replace that if you can. It might work with two 9800GTX+s, but I don't trust Raidmax PSUs at all.
1 - 11 of 11 Posts
