Originally Posted by msremmert ![]() Yeah, you want to use the set up I used on my 360 back when I was using XP. Run a cable to the PC and have it output your PS3's audio over your 5.1 set up. I had to dig up a few images of your Audigy 2 zs online and I can see from the back plate that it has a Line-In, though I cannot remember if that can be converted into a coax input in the control panel. It's been a long time since I've used one of these cards. I can't seem to find anything online that suggests it can do this though. If it can (and that's IF, you're gonna need to dig around in your control panel to find this one out I'm afraid) then you'll need one of these things : http://www.partsexpress.com/pe/showd...number=180-961 I have no idea where you guys buy your stuff but I did find the item you require on a US site. If one of those 3.5mm jacks on the back of your card can be used as a coax input, then just use a standard 3.5mm to RCA cable (cable with the plugs with the red/white cables) and the audio should come from one of the RCA plugs as it will only be a "mono" input on your PC for the digital in anyway. Should you choose to spend more money on your cables, then that's up to you. With regards to the X-Fi's ability to decode Dolby Digital/DTS via a S/PDIF input, I still cannot for the love of me get on Creative's site, (and I've tried with 2 PCs and my phone now) but from what I remember, all of the original X-Fi cards have the decoder. So the cards that definitely do: X-Fi Extreme Music (original one) X-Fi Platinum (one I use and has internal I/O bay, some of the newer cards have the optical in/out put on the back plate of the card these days) X-Fi Platinum Fatal1ty (same as the Platinum but has 64mb X-Ram is endorsed by a man who's mouth is smaller than the hole on the end of my dick) X-Fi Elite (original incarnation) There are a list of model numbers of all the cards that do and don't include the decoder and it's on their site, but without access I cannot tell you I'm afraid, so you'll have to do that bit yourself if you can get on their site. Some of the newer cards do, some of them don't, so it'll be a bit hit/miss I'm afraid. If you can't get the 5.1 decoding, then just un-mute the digital input, set it to output 2 channel PCM on your PS3 (it can do that right?...) and just use the CMSS feature on the card to upmix it into 5.1. It won't be true 5.1 but it's better than a kick in the teeth. |
Originally Posted by stevebaz ![]() Xonar D2X A very detailed review: http://techreport.com/articles.x/14500/21 Gets the editors choice. However i see you have XP, so you would be better with a creative. However if you plan to upgrade to vista, Xonar is the better card. |
