1 - 7 of 7 Posts
I have HD 555 and just ordered HD 558. I been looking around for headphone amps and have my eye on the Fiio E9 and possible the E7 dac- amp to go with it. If i do this that means i will loose my sound card settings for gamer mode "sound blaster X-fi titanuim sound card". So if i use the E7 Dac it will bypass my sound card, so should i just get the E9 desktop amp or should i get a better sound card that has a built in dac and amp? Will just having the Fiio E9 amp work with my sound card or not? If i should get a new sound card what would you recommend?
I myself have replaced my X-fi Xtreme music with a Fiio E10 and I'm loving it. Even coming from the xtreme music's software tweaks such as Bass Boost and Crystalizer ( I know, I know
) the Fiio E10 amazes me. Unlike just getting an amp, a DAC makes a big difference in sound.
I am currently using my X-fi for my microphone only, and my Fiio E10 as my "soundcard". I never really cared for the audio features of my sound card in games, but if those gaming features are crucial then I would probably get a sound card.
The good thing about the E9/E10 is that you can also use it with a laptop
AKA StubbornGreek
Which sound card are you using? You can use the e9 with your setup and keep the positional audio (what I currently use).
Also, don't go for the built in amp on sound cards as they are far inferior to dedicated hardware. GL
Originally Posted by sloppyjoe123 View Post
Just get the STX. It has a DAC and an amp and it is better than the Fiio E7/E9 combo.
Only DAC wise.
1 - 7 of 7 Posts
