1 - 12 of 12 Posts
Her's a new one
Thanks man
Discussion Starter · #6 ·
When first trying water cooling what differences did you guys see? I'm still on air and I'm scared I'm gonna spring a leak or somthing if I try water cooling, what kits should I be looking at what ones should I avoid? thx derk.
Discussion Starter · #8 ·
Yeah gonna try ,thx
Discussion Starter · #9 ·
Originally Posted by Derk0990
Yeah gonna try ,thx
there they are ! not very good pics though
I'll try to size some others this weekend
I Don't think I'll run it that long at those speeds, anything higher and the heat just keeps rising till it reboots , Runs constantly at 3.3 with no problems, But I can get it to boot up at 3.9, so I'm thinking of switching to water.
Discussion Starter · #12 ·
Originally Posted by blob
Build your own custom water cooling, do not buy a kit.
I was thinking the same thing
somthing with a crazy pump on it
1 - 12 of 12 Posts
