Originally Posted by mcg75
M4 has proven reliability and is the best bang for the buck.
In my case, the Corsair and OCZ are cheaper in price than the M4 but not by much.
I still recently bought the M4 over the others as I didn't want any risks of BSOD problems some people get with Sandforce and the M4 comes close to the others with the 09 Firmware.
So I recommend the M4 if you don't want to take the risk.
I also recommend the Intel SSDs as they seem to be reliable too but every Intel SSD I seen when looking to order was alot more expensive than the others for what you get.
And I only recommend the Corsair Force 3 if you are not concerned about the problems with sandforce and want the fastest (probably) drive.
I don't recommend OCZ as I found they were a bit more expensive than Corsair (At least where I am) and Corsair has better customer support
