1 - 5 of 5 Posts
Science
Ok my system is as follows below: I need to upgrade my mobo and cpu, and video card and good cheap ideas i only make 6.00 an hour so lower the better has to get good framesin new games?
The nvidia 7600 GT is the best bang for buck nvidia graphics card. Get the DFI 939 expert board so you can keep your ram. And i suggest the AMD X2 4400+ processor. Good luck with your new PC!
Good and cheep with the old vid card..<br>
ASRock Dual Vista which supports both AGP and SLIx16 for future vid card upgradability and good OCability.<br>
If you inted to move up in the vid card to PCIe, the Biostar TForce 939 has a good onboard vid. Or the same basic but AM2 TForce 939 but the AM2 requires DDR2 RAM.<br>
So if you go 939 which allows you to use your current RAM.<br>
Biostar TForce 939 with OB video (not the GForce version) (Good OCability) About $70<br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813138264" target="_blank">http://www.newegg.com/Product/Produc...82E16813138264</a><br>
Or if your getting a SLI vid card, the and dont mind a MIR The SLI versions is $75 after the rebate. (No onboard Video, card needed)<br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813138272" target="_blank">http://www.newegg.com/Product/Produc...82E16813138272</a><br>
Either a sandy 3700 for a single core solution $90<br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16819103622" target="_blank">http://www.newegg.com/Product/Produc...82E16819103622</a><br>
Or an Opteron 144 $80<br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16819103600" target="_blank">http://www.newegg.com/Product/Produc...82E16819103600</a><br>
Or a Opty 165 for a dual core. $170<br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16819103588" target="_blank">http://www.newegg.com/Product/Produc...82E16819103588</a><br><br>
If you need a good HSF on the cheep $16 + S&H<br><a href="http://www.provantage.com/arctic-acfzp64~7ARCT002.htm" target="_blank">http://www.provantage.com/arctic-acfzp64~7ARCT002.htm</a>
Science
Discussion Starter #5
well i am saving up right now for after thanksgiving sale to get some 7.1 surround speakers., then i will save up for college and compy, so idk im just trying to plan ahead i knwo that new and betetr things will be out but i can dream, so right know lefts say 300 to 400 approx
1 - 5 of 5 Posts
