Well, if you shut it down for the night often, it's likely that you won't finish too many WU's (you could miss deadlines). If you just restart the computer every now and then, but leave it on through the night, you should be fine.
Either way, you will get work done. You may not compete for points, but you said that's not a goal for you.
Oh, PS... fill in your system specs
