1 - 20 of 25 Posts
ok so my friend gave me a unopened box of SUSELinux10.1,i think it they sell it at bestbuy and i was thinking of installing it on my amd 939 rig that i just got up and running and since i am using that windows on my other rig i dont have a os for this one<br />
<br />
i have never used linux or even researched it very much so... <br />
<br />
are there any tips for getting started, i know that alot of games and programs arent supported by linux but this rig will mainly be a folding rig and overclock test bed of sorts if i come across any more 939 cpus that i feel like running <br />
<br />
this disk says it has both 32bit and 64bit versions on it for amd64/intelem64t, will i need any special drivers for this as far as setting up a raid (is that possible with thissince i have two raptors that ill be using) <br />
and any programs i should get before i get started <br />
<br />
thanks for any help or suggestions and please try to keep it somewhat simple at first thanks
OVERCLOCK IT OR DIE
- Be prepared to read a lot. If you run into trouble try searching for it on the internet first using your favorite search engine.<br />
<br />
- Don't get discouraged if something doesn't work like in windows. It's not windows.<br />
<br />
- Read the user manual. Seriously.
thanks, ive kind of prepared my self for a long learning curve, i understand its alot different then windows <br />
<br />
is this brand of linux ok how does it compare to other versions of linux<br />
<br />
edit this is produced by NOVELL
OVERCLOCK IT OR DIE
Honestly? I'd start with an easy Linux like Fedora or Ubuntu. I have very limited exposure to SuSe but from what I remember it wasn't that bad.
Reactions: MADMAX22
Discussion Starter #5
well the manual makes it seem straight forward enough, i think ill start my struggle after dinner, thanks and im sure ill be back later posting a question or two
It isn't that bad. <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /> I can help you if you get stuck, along with many other people here. <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
SuSE is a good distro, I think you'll like it and shouldn't have many problems with it. I'd suggest installing the 32bit version, you'll find driver support to be better.<br />
<br />
Is it SuSE 10.1 or SuSE Linux Enterprise Desktop 10?
<tr>
SUSELinux10.1
</td>
</tr>
</table>
</div>I would say SuSE 10.1
Discussion Starter #9
it just says suselinux 10.1 <br />
<br />
comes with firefox,openoffice.org,novell apparmor, xen <br />
<br />
<tr>
thinl you'll like it and should have many problems with it.
</td>
</tr>
</table>
</div> lol i hope thats a typo
Discussion Starter #10
and which do you suggest kde or gnome for the desktop
<tr>
<div>
Originally Posted by <strong>The_Jester</strong>
</div>
<div style="font-style:italic">I would say SuSE 10.1</div>
</td>
</tr>
</table>
</div><img src="/images/smilies/doh.gif" border="0" alt="" title="Doh" class="inlineimg" /> lol, the post about Novell throw me off.<br />
<br />
<br />
<tr>
I hope that was a typo
</td>
</tr>
</table>
</div>Yeah I do that often when I'm trying to type fast.<br />
<br />
I like Gnome, you can install both, along with blackbox, Openbox, FVWM,...
<tr>
<div>
Originally Posted by <strong>MADMAX22</strong>
</div>
<div style="font-style:italic">and which do you suggest kde or gnome for the desktop</div>
</td>
</tr>
</table>
</div>Both. Install both and switch between them. You can find out which you prefer. I prefer Gnome, but others like KDE and SOME like Xfce, Fluxbox or NON at all (zomg!)
Reactions: MADMAX22
Not that bad, As you use it and use it and get used to it you will wonder how you liked windows
Reactions: MADMAX22
OVERCLOCK IT OR DIE
<tr>
<div>
Originally Posted by <strong>BenHagerty</strong>
</div>
<div style="font-style:italic">Not that bad, As you use it and use it and get used to it you will wonder how you liked windows</div>
</td>
</tr>
</table>
</div>Well it's not really a Windows vs Linux contest for me as it is Price vs LOLFREE. I use XP on my main machine, but like screw paying for an OS for my file server + the old ass laptop I have.
During the install when you get to this point:<br />
<img src="http://i69.photobucket.com/albums/i66/OneDangerousHobo/9.gif" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
click on the expert tab at the top and then click on software on the side. Then you'll be able to select both Gnome and KDE to be installed. A little easier than doing it later.
Reactions: MADMAX22
Discussion Starter #16
cool thanks alot guys
Discussion Starter #17
ok first question , i installed and everything seems to be going good , finished the install and everyhting boots up till i get to the window that has like 5 selections to boot from so i choose the first one which is the main load i think and everything looks good and it fires up but then the monitor says input not supported and stays blank,<br><br>
now if i boot into the safe mode or text version it lets me get into the command promp or whatever and i can change the video adapter there and everything shows up fine but when i reboot it does the same thing again<br><br>
i can get into the yast controller or whatever it is that shows you all the info and everything , anyways any suggestions
Discussion Starter #18
well i got er up and running and everything seems cool so far, very nice interface, i dont know whats up but i hae to boot in via the xen option to get it to display other wise it says input not supported on my monitor after i get to the load part and im still having problems trying to load the invidia drivers but oh well ill work on it later<br />
<br />
now i need to get some cpu monitoring software and stuff so i can see how high i can this fx55 and start folding
For nvidia drivers:<br />
Write these steps down!<br />
<br />
get the driver <a href="http://www.nvidia.com/object/unix.html" target="_blank">here</a>.<br />
save it in your home folder. then press Ctrl+Alt+F1, this is were writing the steps down will help you.<br />
<br />
now you should see a login prompt, so login as root.<br />
then type in the following commands.<br />
<div class="bbcode_code">
<div class="bbcode_code_head">Code:</div>
<pre><code>init 3
cd /home/*username (now you should be in the folder that the driver was saved in)
chmod +x NVIDIA .....(just press tab to complete it)
./NVIDIA......(tab again)</code></pre>
</div>then the install process will begin, just say yes to every thing.<br />
Then you can either reboot: shutdown -r now<br />
-or- <br />
start X back up(this will be you log back in): init 5
Discussion Starter #20
thanks
1 - 20 of 25 Posts
