new to OCN and overclocking in general
278 Views 3 Replies 2 Participants Last post by  lespaul5895
Well the title says it all. I'm new to overclocking and am looking for some advice. I've read through a few guides and started messing with amd overdrive. I am completely lost looking through my bios on this foxconn. I found a setting to change the cpu frequency but can't seem to find much else. Anyone who has any advice on this mobo it would be greatly appreciated.
Using AMD OD I was able to take the 2.5 GHz to 3.1 GHz just using the auto clock feature.
1 - 4 of 4 Posts
AMD overdrive was EXTREMELY buggy for me in the past. I never recommend software overclocks.
Go into your system bios and check out the options from there. First before you even try overclocking read some threads on here about Testing an overclock.
You can get a cpu to show the highest speeds in the world, but if want your computer usable I suggest you test stability.
You will need a stress test. I use Prime 95 or Orthos (both can easily be found w/ google). Also you will need to test memory ( i do about 20 minutes before every pushed overclock before booting into windows as to not corrupt my operating system.
( THIS IS THE REASON I HATE SOFTWARE OVERCLOCKS, YOU PUSH TOO FAR YOUR OS CAN BECOME CORRUPTED)
Also be familiar w/ the BIOS reset jumper in the event of an unsuccessful overclock. Make you turn off ANY AMD cool and quiet features that may try to "step" your processor speed down during inactivity.
yeah I have both prime and orthos and will run them when ocing. I'm just not familiar with this particular bios and how to navigate all the many many options.
I must be really blind because I can't find the setting to change the multiplier >.<
1 - 4 of 4 Posts
