haha, I dont think that anyone really intends to ignore new people... especially since the thread is barely an hr old.
Anyway, I dont know if I really qualify for this, as I'm still learning about my 720 BE, but I do have a pretty good idea how all of this works in general.
a) since FSB has been replaced, things have changed, but its actually pretty simple.
The HT replaced the FSB in how it communicates with all of the other components on the mobo. The reference clock and a multi still determines the CPU speed, and now the only real difference is that the HT speed is based off of the reference clock and its own HT multi.
The NB is what communicates with the memory through the IMC, so a higher NB clock will make for faster memory access times and the like.
b)Since the introduction of DDR2 and 3, the ram will now run at speeds higher than twice the reference clock (which is the 1:1 ratio that you're talking about). If your ram is rated at DDR1066, and your reference clock is 200, then there is no way that you would want to run a 1:1 divider, because you would only be running DDR400. So I would leave it where it is for right now, or lower it to DDR800 speeds if you're messing with the reference clock.
c) I'll be honest here, this part lost me. You say you cannot change it, but that you can change it...? the HT link can run up to 2.6GHz if i'm not mistaken, so you should be fine right now. So If you could clarify this part a little, we might be able to help out more.
d) what kinds of options do you have that you cant figure out?
Good luck, and welcome to the forum
