1 - 20 of 22 Posts
hey guyz,<br>
I have an<br>
intel 915 3.0ghz,<br>
1gb ram,nvidia 6200 (256),<br><br><br>
please guyz tell me how to overclock my machine...if anyother specs are required..plz ask.....i also want 2 overclock my graphic card...and also increase my ram performance...w8in 4 a reply...thanks in advance.....<br><br>
p.s. i havent changed any settings..so u can imagine the settings to be default...
What kind of motherboard do you have?
first off welcome to overclock.net<br>
ide recommend going into USER CP (control panel)<br>
and then edit your system specs.<br>
to fully understand a machine we will need to know all of your specs <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br>
then you can post in the intel/amd forum for help with overclocking <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
then you cant overclock.. by default all intel motherboards have their multipliers locked so if it is an INTEL motherboard 9/10 says you cannot overclock it
i mis read.. you said it is a 915 chipset o_O errr one other question did you buy your computer out of a store..<br>
emachines<br>
dell<br>
gateway<br>
ect. ?
okay if you look on your motherboard is it an INTEL board or is it made by a secondary party like ASUS or ABIT or some other brand?
Discussion Starter #9
<div>Originally Posted by <strong>rabies229</strong></div>
<div style="font-style:italic;">then you cant overclock.. by default all intel motherboards have their multipliers locked so if it is an INTEL motherboard 9/10 says you cannot overclock it</div>
</td>
</tr></table></div>
<br>
wt bout my graphic card...and is there any other way to overclock my machine???....if not den wt should i have that i can overclock it in future(i mean wt specs or any other pc perphiral or sumthng??)
Discussion Starter #10
<div style="font-style:italic;">okay if you look on your motherboard is it an INTEL board or is it made by a secondary party like ASUS or ABIT or some other brand?</div>
</td>
</tr></table></div>
<br>
its an intel..actully i din trust amd cuz it was new b4 so i made it an intel...
why don't you trust Amd? And btw, i dont know of many Intel mobo's (if any)
Discussion Starter #12
<div>Originally Posted by <strong>Jakg</strong></div>
<div style="font-style:italic;">why don't you trust Amd? And btw, i dont know of many Intel mobo's (if any)</div>
</td>
</tr></table></div>
<br>
it was new at dat time dats y...bt nw if i buy a new 1 den my new make will b amd 4 sure...bt now i want help wid dis 1
Itel made motherboards cannot be overclockede unless they are like an engineering sample or something :S sry
Overclock Failed...
<tr>
<div>
Originally Posted by <strong>safeman</strong>
</div>
<div style="font-style:italic">it was new at dat time dats y...bt nw if i buy a new 1 den my new make will b amd 4 sure...bt now i want help wid dis 1</div>
</td>
</tr>
</table>
</div>Which one?<br />
<a href="http://www.intel.com/products/desktop/motherboard/index.htm?iid=mbd_main+dt" target="_blank">http://www.intel.com/products/deskto...id=mbd_main+dt</a>
Discussion Starter #15
ok...so intel motherboards cannot be overclocked..but how do i go about overclocking my graphic card????
Overclock Failed...
<tr>
<div>
</div>
<div style="font-style:italic">ok...so intel motherboards cannot be overclocked..but how do i go about overclocking my graphic card????</div>
</td>
</tr>
</table>
</div>nTune, Coolbits or RivaTuner.
Download and run cpuz. Post a screen shot of the tabs.
<tr>
<div>
</div>
<div style="font-style:italic">its an intel..actully i din trust amd cuz it was new b4 so i made it an intel...</div>
</td>
</tr>
</table>
</div>But right now Intel is better than AMD.. the core 2 duo processors kick their asses.<br />
<br />
But well, about the motherboard, you can always look in the BIOS if you see an option called 'FSB frequency' or similar. If you want to olverclock you have to up that one. On a P4 it's 200x15 (= 3000Mhz) so if it would be enabled you can raise it a bit and see if your pc will boot (so like 210x15)<br />
I can't guarantee the option is available but if you don't take the shot you'll always miss <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick out tounge caps" class="inlineimg" /><br />
<br />
Note that you won't notice a large performace increase, as that was what you are thinking/hoping for. I put my old P4 3.4 to 3.7 and didn't even notice 1fps increase in games, only more heat..<br />
<br />
And you could overclock your videocard but I doubt you'll see much of an performance increase as well, as it is a very poor performing card
Discussion Starter #20
<tr>
<div>
Originally Posted by <strong>Radeon915</strong>
</div>
<div style="font-style:italic">But right now Intel is better than AMD.. the core 2 duo processors kick their asses.</div>
</td>
</tr>
</table>
</div>ohk...so these are also 64-bit processors rite???...n btw core 2 extreme processor is better than core 2 duo..isnt it??...
1 - 20 of 22 Posts
