1 - 4 of 4 Posts
I've never been big on programming, and I think it's about time I start.
I think I'm gonna start with Python, unless you guys have any other suggestions and why?
Also, what is the general approach to start? Should I have a general idea on what I want to build, or learn the general library first?
Python is solid. I would definitely recommend it.
Also, don't get stuck on fancy UIs - most of what you'll be doing involves command line. The GUI is just there to help users access what's going on in the background.
I always recommend C#. It is a more solid representation of what you will see in a professional field. Although you may not ever use it professionally, i think that's important in a first language. And at the same time spares you memory management until you can get a hang of code. After that i suggest moving to full blown C++, which isn't a big step from there.
Note i do this for a living.
I wrote a guide for it based on this (and other) recommendations i have given people.
http://www.overclock.net/coding-prog...ml#post3791626
1 - 4 of 4 Posts
