1 - 2 of 2 Posts
<a href="http://img115.imageshack.us/my.php?image=newfoldervw1.jpg" target="_blank"><img src="http://img115.imageshack.us/img115/7735/newfoldervw1.th.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></a><br />
<br />
I just rid this Dell Dimension 3000 (Celery Processor) of some nasty virus' and Malware (thanks for all that assisted a couple of weeks ago). The owner went on maternity leave and said "I could do what I wanted with it". Since I couldn't find my plastique and detonators I put it to work.<br />
<br />
P.S. When I config the [email protected] I only have to do 2 things...<br />
<br />
1) Name = Syrillian<br />
2) Team - 37726<br />
<br />
right? Thanks.
Welcome to the team. <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
Yes, just set all of your rigs to the same username and team 37726, and you'll be all set. If you do fold on your Allendale, just create two folding directories with the console version. When you run the config on each console, be sure to have a different machine ID on each directory (it'll prompt you for this; the numbers don't matter as long as they're different).
1 - 2 of 2 Posts
