New Tv Dual Display?
776 Views 28 Replies 9 Participants Last post by  JMT668
hey guys just got a 32" HDTV and i want to use it as my 2nd monitor i have a 20" samsung as my main one and i want to set it up so i can have my full desktop on both screens at the same time how can i do this?
i have both monitors up and running but i can only get a split display between them but i want the smae thing on both, any ideas?
1 - 20 of 29 Posts
Change the mode to mirror in Nvidia control centre.
al give that a try!
cant find Mirror in Nvidia Controlle panel?
Just go to setup milti displays in the Nvidia panel and click on the "Clone" dot. It will mirror your display.
:Edit, I'm uploading a screen shot
Go into nVidia Control Panel, then select manage multiple displays, then check both so it shows 1 and 2 next to eachother then there is an option for Mirroring or cloning display to second monitor.
click on the pic for a larger view. you will see on the left, there are three options. You want the one in the middle.
nVidia control panel looks different than it used to... Under "setup multiple displays" it should have 3 bubbles to check. One of them should say "clone: display the same image on both monitors" or something along those lines. I only have one display hooked up so the option isn't there for me or I'd try to be more specific.
mine is slightl different from that pic TDN
Have you updated your drivers?
Try right clicking on your desktop and click on personalize. Then click on the display tab at the bottom. See if you can turn it on in there.
drivers are upto date
Try this program:
Ultramon
You'll want to clone the display, but that will only work if they are both at the same resolution, otherwise one will look goofy.
that works but lags like hell!!
The program? Works great for me. Could be your graphics card struggling.
ive got a 512 ddr3 9500GT do you think that would struggle?
1 - 20 of 29 Posts
