Hey everyone, I just found a sweet case for 45 bux online for my server rig. It's the Antec DF-10. I don't normally post on cases at all but since it's so hard to find a good case for cheap with a black interior and window (not that I really need it for a server), I figure I'd see what other people thought of this thing. It seems to have decent cable management and layout for its price point. Does anyone else have this case? I haven't read any reviews on it but so far I'm impressed just from looking at the pictures.
From Antec:
Bottom-mounted power supply isolates heat
CPU cutout allows for easy installation of CPU coolers
Washable fan filters allow for easy cleaning
Cable routing compartment organizes cables discreetly
11 drive bays
- 6 x internal 3.5"
- 3 x external 5.25"
- 1 x internal bottom-mounted 2.5" SSD bay
Advanced cooling system
- 1 x top 140mm TwoCool™ fan
- 1 x rear 120mm TwoCool™ fan
- 1 x side 120 mm fan for graphics cards (optional)
7 expansion slots to support multiple graphics cards
Maximum video card size: 11.5"/292 mm
Stylish blacked-out interior
Windowed side panel
Front ports
- 2 x USB 2.0
- Audio (AC'97 and HDA compatible) In and Out
Motherboards: Mini-ITX, microATX, Standard ATX
Includes standard case lock slot for integrated anti-theft protection
Power supply not included
Unit Dimension
- 488 mm (H) x 198 mm (W) x 497 mm (D)
- 19.2" (H) x 7.8" (W) x 19.6" (D)
Package Dimension
- 565 mm (H) x 275 mm (W) x 570 mm (D)
- 22.2" (H) x 10.8" (W) x 22.4" (D)
Weight
- Net : 14.5 lbs / 6.6 kg
- Gross : 17.5 lbs / 8.0 kg
http://store.antec.com/Product/darkFleet/df-10/0-761345-15210-5.aspx
From Antec:
11 drive bays
- 6 x internal 3.5"
Windowed side panel
Front ports
- 2 x USB 2.0
Unit Dimension
Package Dimension
Weight
