1 - 12 of 12 Posts
Hi,<br><br>
I'm glad I had an opportunity to join this forum. Please forgive me as these questions are rather amatuer. This will be my 1st time building a system. Recently I have acquired a DFI Infinity 975X motherbroad with an Intel Core 2Duo E6600 processor. However, I do not know which type of ram would be sufficient in building this unit. I was hoping to use 4 @ 1 GB of G.Skill PC2 6400 with 4-4-4-12 timing and a CAS Latency of 4. This unit would be used primarily as a gaming unit. I would like to ask the opinion of all the members of Overlock.net to see if this would be sufficient. Thank you very much!
Go for the G.skill and welcome
Welcome. Once your parts arrive (or right now), go ahead and fill in your system specs.
I wouldn't take 4 sticks, it is way slower in dual channel mode then 2, at least on AMD chipsets it is.<br><br>
You will be better of saving the money and getting 2 @ 1 GB , besides it not that much of a difference, not with the current games.<br><br>
Welocome to OC.net BTW
<div>Originally Posted by <strong>Hellgy</strong></div>
<div style="font-style:italic;">I wouldn't take 4 sticks, it is way slower in dual channel mode then 2, at least on AMD chipsets it is.<br><br>
Welocome to Overclock.net BTW</div>
</td>
</tr></table></div>
Intel doesnt have much ofa proble with all 4 slots. Either way, 4gb is useless, 2gb is plent enough so save yourself ~300 dollars.
Discussion Starter #6
Well I was reading about CAS Latency. I guess where I'm really confused about is technically you want the CAS Latency as low as possible right? So buying RAM that has a CAS Latency of 5 compared to one that has a CAS Latency of 4, the one with the lower Latency would run faster correct?
<div>Originally Posted by <strong>changster8260</strong></div>
<div style="font-style:italic;">Well I was reading about CAS Latency. I guess where I'm really confused about is technically you want the CAS Latency as low as possible right? So buying RAM that has a CAS Latency of 5 compared to one that has a CAS Latency of 4, the one with the lower Latency would run faster correct?</div>
</td>
</tr></table></div>
For Conroe the difference between a CAS latency between 4 and 5 is very minimal. In fact I can barely find any differeces in benchmarking, so go ahead and get the 5 if you wish.
Discussion Starter #8
So far I've got these parts:<br>
1. Intel Core 2 Duo E6600<br>
2. DFI Infinity 975X<br>
3. G.Skill 2GB (2 @ 1GB) Latency: 4<br>
So my next concern is if I'm overclocking this computer, what type of Cooling recommendations can be made? I was thinking about a Zalman?
<div style="font-style:italic;">So far I've got these parts:<br>
So my next concern is if I'm overclocking this computer, what type of Cooling recommendations can be made? I was thinking about a Zalman?</div>
</td>
</tr></table></div>
Zalmans aren't that great. My reccomendation would be the <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835106061" target="_blank">Big Typhoon</a>. With my case flow and the BT I run ambient temps at idle.
Discussion Starter #10
So you don't think a water cooling system is necessary right? I've had many friends who are die hard fans of these water cooling systems and stand by them so much.
I would look into a different motherboard. The DFI is a bit of a pain in the neck. The lastest official BIOS has only limited overclocking options (very limited RAM settings, basically only timings, RAM speed, and voltage). Also, no way to change multi.<br><br>
I am using a Beta version of the BIOS right now, and it's ok..hitting 3.5GHz, but not able to get any higher. I would get 2GB RAM and a better motherboard like the ASUS P5W DH Deluxe or the new ABIT A9W MAX (although that one only has one PCI slot)<br><br>
Water cooling will allow a better overclock, to about 3.8GHz or so. It's up to you whether it's worth the extra money.<br>
Good air coolers are the big Noctua, the Scythe Infininity, and the second generation of the Thermaltake Big Typhoon.
<div>Originally Posted by <strong>mycomputersucks</strong></div>
<div style="font-style:italic;">For Conroe the difference between a CAS latency between 4 and 5 is very minimal. In fact I can barely find any differeces in benchmarking, so go ahead and get the 5 if you wish.</div>
</td>
</tr></table></div>
Yes but then he can loos the CAS to 5 and squeeze some more MHz out of it...
1 - 12 of 12 Posts
