1 - 8 of 8 Posts
Hi,
This is going to be my first water cooling build and I would like suggestions on radiators. Which ones have you used and why you like them.
I am leaning towards the Cooler Master H500P because I like the look of the case. I know it can support up to two 360 rads. One on top and one in front. I am thinking about sticking with that configuration but going with slim rads. The ones I have looked up so far have a decent fpi, around 20. Because of that I am looking into using 3 Noctua - NF-F12 iPPC 3000 PWM 120 fans, per rad.
I am caught up on deciding on which radiators to use. I want good quality, and performance. Also would like full copper if possible.
Thank you for your time.
I ended up getting lucky and got a 240mm slim XSPC and a 280mm XSPC rad on ebay for 80$ used. I hadnt put them in yet but they're full copper and they look new.
Shooting down fallacies
Overclocker in training
Hi,
Thickness is measured by the outside the actual coils are smaller so although a 30mm sound good a gtx is about 54mm dual core about 45mm+- actual rad coil size.
Single core/ dual core/ dual flow are the basic differences :)
1 - 8 of 8 Posts
