1 - 3 of 3 Posts
It's been a pain in the arse at times but I'm happy with the result, some people said you can't fit an XSPC RX 240 in a Phantom case, you're right! It's a bit of a squeeze but it's secure where it is. Had to drill two holes in the top of the case to screw it in to and being stainless steel, it took nearly an hour....
Here's the list:
EK Supreme HF Full Nickel Water Block
Arctic Cooling MX-3 Thermal Paste
XSPC RX240 Radiator
Two Scythe Gentle Typhoons (AP-15)
XSPC Dual Bay Reservoir/Pump
Laing D5 Pump
XSPC Green/UV Green 7/16" tubing (1/2" barbs)
Primochill UV Blue PVC Hose Clips
1 - 3 of 3 Posts
