1 - 12 of 12 Posts
I got a Powercolour X1800GTO Today - Swapped it with my X800GT as a guy I Know doesnt have enough Power in his Dell to run it.
At first there were a few problems, But got the new drivers and everything seems cool. Im getting a 580W Hiper Modular PSU to replace my crappy 380W on Friday So Im not going see how high this baby goes till I get that
Core are at 56c Just now, which sounds fine. But Im going to wait till I get the new PSU till I take any chances
Wait.....where does the Dell come in?
Oh Oh
Dam Artifacts
I really need to get the new PSU now.
Just to check - It will be my crappy 380W Power supply wont it?
Discussion Starter #4
Power Supply is like 300W and it the CPU + Ram bottleneck it.
Discussion Starter #6
I just tried A Counter Strike Stress test - Average 100FPS which is up 40 from the X800GT But it is artifacting. So would this mean definatly that it is the Power Supply?
Administrator
It looks like a PSU issue to me. However try this first and make sure that all onboard VGA is disabled.
Installing Graphic card driver efficiently!!! When you Update your graphics cards drivers theres ways that you should go about it. Follow these simple steps below.
1.Download and install ''Driver Cleaner'' Here:
http://www.drivercleaner.net/professional.html
2.Uninstall your Current Display drivers such as your ''ATI'' or ''Nvidia'' drivers.
3.Now run ''Driver cleaner'' and depending on the Drivers you have you will have to select either ''ATI'' or ''Nvidia'' from the drop down menu. Only select the main title of the driver in the drop down such as just ''ATI'' or ''Nvidia''
4.Once you have selected Your driver click on the ''Start'' button and this will now start the driver cleaning process. ( Do this twice to be sure )
5.Now reboot your system and Download the latest Nvidia or ATI and go ahead and install them.
Doing this avoids driver corruption and conflicts so you can now enjoy smooth gameplay.
Discussion Starter #9
Originally Posted by Ace of Spades
Try removing some hardware, like the extra HDD and thats about it it seems.
Hmm lets hope the new PSU sorts this problem
I Did that, Unplugged my DVD Drive + Neon lights - Worked fine
Im ordering the new PSU on Friday when I get paid
Discussion Starter #12
Just though Id update - I won a Hiper 580W Type R on ebay for £55 shipped as a pose to £70 in shops
Once it arrives I will be back to usual CSS
And really see what this card can do
Thanks All REP +
1 - 12 of 12 Posts
