1 - 20 of 29 Posts
Ok so I got a 3400+ dtr mobile 64, and a DFI lanparty UT nf3 250gb
It booted up at 800mhz
Do I need to get a bios fix so it'l go to its stock speed?
Or do I just start jacking up the vcore and multiplier tell im back at 2.2ghz?
Just dunno if I need to get a new bios, or just kick it up to 1.5v vcore and 11x..
The vcore is currently at 1.09 according to everest lol... And I have it at 8x clock at 1.6ghz lol
Just set it to 200x11 and 1.4volts (true mobile, right?) and go from there. I personally saw no benefit from any of the hacked BIOSs, but you should get the 9/14 for good measure.
You need to download DFI latest bios 9/14 version.
Or if you're planning for some crazy overclocking and need some extra voltages, memtest, and a few other DTR/Mobile Fixes you can download modded Oskar WU bios from dfistreet.com
Discussion Starter #4
I already got a hacked one, forgot to add that... I thought the hacked one would make it go right up to the right settings.
You tell me if its a true mobile haha, I dont really know much, cept what you guys tell me
http://www.gameve.com/gve/Store/Prod...CPU-AMD64M-003
Nope, that's a DTR so it should be 1.5 volts. There's no BIOS that sets the correct freuqencies automatically, just some that improve power cycles and enable better overclocking options (like up to 4.0volts vdimm).
Discussion Starter #7
Meh.. Now my computers crashed twice =\\
First time it crashed after about 15 minutes of prime95, just rebooted.. Now its rebooted without prime95.. It just kicks off and back on =\\
Voltages arn't terribly bad..
11.9
3.26
5.05
with a multimeter
cpu at 200x11 with 1.5volts, everest shows 1.47v
I supposedly have a DTR and that serial number is alot different than mine.
DTRs start with AMA, 62-watt "true" mobiles start with AMN. And Desktop chips start with ADA.
11.9
3.26
5.05
with a multimeter
http://www.dfi-street.com/forum/showthread.php?t=2073
Try the offical 9/14.
Discussion Starter #12
Yiffy you know of any good overclocking guides for this board?
I dont know crap
edit: whenever I flash the bios, do I type /F at the end? Thats what I did last time, I read it on dfi's site
Dunno, only times I've flashed this board's BIOS was with WinFlash and the Diamond Flash Image utility.
DeaDlock posted two pretty complete Overclocking guides for this board in the oc.net Answers thing.
You try the new BIOS?
Only other reason I can think of why it won't open up, mine does 2400Mhz at 1.45volts
Discussion Starter #16
I can't seem to find it in the guide, is there anywhere to lock the Pci or eide drives so there not overclocking?
I got the new bios
didn't have any reboot problems tell just a second ago, rebooted again.. only after about 2 minutes of being in windows.... Never rebooted over the last 16 hours its been running.
edit: uh in sensor on everest, it shows "+2.5v" as in thats what its suppsoed to be, and out to the right it shows 1.68.....
What is that and where do I set it? or do you have any idea
Have you got the cool & quiet turned off?
I don't think there is any 2.5v device in a computer
I dunno... might be a bad board. nF3 has automatic locks, but sometimes setting the AGP frequency to 67MHz helps them "wake-up".
Cant remember ever seeing that.
1 - 20 of 29 Posts
