I was looking for a answer how to overclock my cpu. first ive got a very nice zalman heatsink-fan combo and my cpu is never above 100 degrees farenheight. ive got a good amount of fans. well ive seen people to be told to post the cpuz info so heres mine please help.
vidcard-radeon 9800 pro 256
hdd-80gb western digital 8mb buffer
1gig ram 2x512 sticks of crucial
CPUID Output
Number of CPUs1
APIC ID0
NameAMD Athlon 64 3200+
Code nameNewCastle
SpecificationAMD Athlon(tm) 64 Processor 3200+
Family/Model/SteppingFC0
Extended Family/ModelF/C
Brand ID4
PackageSocket 754
Core SteppingDH7-CG
Technology0.13µ
Instructions SetsMMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE, SSE2, x86-64
Clock Speed2202.9 MHz
Clock multiplierx11.0
HTT Bus Frequency200.3 MHz
P-Rating3200+
L1 Data Cache64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache512 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed2202.9 MHz (Full)
L2 LocationOn Chip
L2 Data Prefetch Logicyes
L2 Bus Width128 bits
Chipset
NorthbridgeVIA K8T800 (VT8383) rev. 1
SouthbridgeVIA VT8237 rev. 0
Graphic InterfaceAGP
AGP Revision3.5
AGP Transfert Rate8x
AGP SBAsupported, enabled
AGP Aperture64 MBytes
Memory TypeDDR
Memory Size1024 MBytes
Memory Frequency157.3 MHz (CPU/14.0)
CAS#2.5
RAS# to CAS#3
RAS# Precharge3
Cycle Time (tRAS)6
Bank Cycle Time (tRC)10
DRAM Idle Timer16
Memory SPD
DIMM #1
General
Memory typeDDR-SDRAM
Manufacturer (ID)Micron Technology (2CFFFFFFFFFFFFFF)
Size512 MBytes
Max bandwidthPC2700 (166 MHz)
Part number
Serial number
Manufacturing dateWeek 29/Year 03
Attributes
Number of banks2
Data width64 bits
CorrectionNone
Registeredno
Bufferedno
Timings table
Frequency (MHz)133166
CAS#2.02.5
RAS# to CAS# delay33
RAS# Precharge33
TRAS#67
DIMM #2
General
Manufacturer (ID)
Size512 MBytes
Max bandwidthPC3200 (200 MHz)
Part number
Serial number000000FF
Manufacturing dateWeek 00/Year 00
Attributes
Number of banks2
Data width64 bits
CorrectionNone
Registeredno
Bufferedno
Timings table
Frequency (MHz)133166200
CAS#2.02.53.0
RAS# to CAS# delay233
RAS# Precharge233
TRAS#678
Monitoring
Sensor ChipWinbond W83697HF
DMI
DMI BIOS
BIOS #1
vendorAmerican Megatrends Inc.
version1004.006
date08/03/2004
DMI System Information
System #1
manufacturerTo Be Filled By O.E.M.
productTo Be Filled By O.E.M.
versionTo Be Filled By O.E.M.
serialTo Be Filled By O.E.M.
UUID
DMI Baseboard
Baseboard #1
vendorASUSTeK Computer Inc.
modelK8VSEDX
revisionRev 2.00
serial
DMI Processor
CPU #1
manufacturerAMD
modelAMD Athlon(tm) 64 Processor 3200+
clock speed2200.0MHz
FSB speed200.0MHz
multiplier11.0x
DMI Memory Controller
Memory Controller #1
correction64-bit ECC
Max module size1024MBytes
DMI Memory Module
Memory Module #1
designationDIMM0
size512MBytes (double bank)
Memory Module #2
designationDIMM1
Memory Module #3
designationDIMM2
DMI Physical Memory Array
Physical Memory Array #1
locationMotherboard
usageSystem Memory
correctionNone
max capacity4096MBytes
max# of devices3
DMI Memory Device
Memory Device #1
designationDIMM0
formatDIMM
typeSDRAM
total width64bits
data width64bits
size512MBytes
Memory Device #2
designationDIMM1
formatDIMM
typeSDRAM
total width64bits
data width64bits
size512MBytes
Memory Device #3
designationDIMM2
formatDIMM
typeunknown
Software
Windows VersionMicrosoft Windows XP Professional Service Pack 1 (Build 2600)
DirectX Version9.0c
CPUID Output
Number of CPUs1
APIC ID0
Code nameNewCastle
Brand ID4
PackageSocket 754
Core SteppingDH7-CG
Technology0.13µ
P-Rating3200+
L2 LocationOn Chip
Chipset
AGP Revision3.5
Memory TypeDDR
CAS#2.5
RAS# to CAS#3
RAS# Precharge3
Cycle Time (tRAS)6
DRAM Idle Timer16
Memory SPD
DIMM #1
General
Size512 MBytes
Part number
Serial number
Attributes
Number of banks2
Data width64 bits
CorrectionNone
Registeredno
Bufferedno
Timings table
CAS#2.02.5
RAS# Precharge33
TRAS#67
DIMM #2
General
Manufacturer (ID)
Size512 MBytes
Part number
Attributes
Number of banks2
Data width64 bits
CorrectionNone
Registeredno
Bufferedno
Timings table
CAS#2.02.53.0
RAS# Precharge233
TRAS#678
Monitoring
DMI
DMI BIOS
BIOS #1
version1004.006
date08/03/2004
System #1
UUID
DMI Baseboard
Baseboard #1
modelK8VSEDX
revisionRev 2.00
serial
DMI Processor
CPU #1
manufacturerAMD
FSB speed200.0MHz
multiplier11.0x
DMI Memory Module
Memory Module #1
designationDIMM0
Memory Module #2
designationDIMM1
Memory Module #3
designationDIMM2
locationMotherboard
usageSystem Memory
correctionNone
max# of devices3
DMI Memory Device
Memory Device #1
designationDIMM0
formatDIMM
typeSDRAM
total width64bits
data width64bits
size512MBytes
Memory Device #2
designationDIMM1
formatDIMM
typeSDRAM
total width64bits
data width64bits
size512MBytes
Memory Device #3
designationDIMM2
formatDIMM
typeunknown
Software
DirectX Version9.0c
