Hello,
I'm new here and maybe someone can help me out with this thing. Let me give you some details.I have a Abit V17 mobo with a P4 HT Processor that operates at 2.6Ghz. Its a Northwood Core with 800 MHz FSB. I Have changed the stock heatsinks on both the Chipset and the processor. They are high performance... I didn't go cheap on cooling. My current untweaked temp's are 30 at Idle and 59 at full load using Prime 95 and HeavyLoad in Windows Xp. These temps are with all the fans at their lowest settings. Now to the question's. Is 30 a normal temp at Idle? When I go into the BIOS the
temp's read differently, 44 with all my fans on low. Celsius speaking of course. Is my processor under load when I'm in the BIOS? I have also tried to overclock my CPU to 2.8 by using the FSB bumping it to 216. That gave me a Chipset speed of 866 MHz. But it worked fine at idle, but when I ran Prime95 and HeavyLoad the Computer abruptly shut off. All my fans where at their highest setting when this happend. I only overclocked thru the FSB. Do you think its necessary to up the core voltage as well? If so where should I set it to? My current is 1.504. Anyone know where I can lock the AGP bus so
it dosent overclock. Is the CPU-AGP-PCI option? Its currently on auto.
Thanks In advance
Thanks In advance
