1 - 6 of 6 Posts
Hi<br />
I just bought a laptop and theres a DVD burner!I finally have one!<br />
So my question is : Whats the difference between DVD+R and DVD-R<br />
Is there a quality difference?<br />
Can my DVD burner burn any DVD?<br />
Thanks
Ive read around a while back, and through personal experience, i don't really see a difference between DVD+R and DVD-R. And if you mean by: can my dvd burner burn any kind" as in DVD+R and DVD-R. Yes, it'll work, whichever one you want. <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
The only point to burn to a DVD+R or DVD-R is the compatibility of your stand-alone DVD player. Some players can use both types just fine, some can only accept one type. Most DVD Players can play movies burned onto DVD+R disks. You'll just have to try it out to see which ones your stand-alone player can read once you burn a movie onto it.<br />
<br />
Xaine99
Reactions: Grosmechantloup
yeah, it's a different format, same size and burning is usually the same. as long as your burner can use both (most-likely can) you just need to see what your DVD player can handle. In my experience +R is more compatable, although both my DVD players can handle both +/-R's (panasonic and Oppo)
1 - 6 of 6 Posts
