1 - 3 of 3 Posts
Greetings to all!
Reading so many threads here -- you guys are rockstars.
I'm doing an i7 950 build with a Gigabyte x58-UD3R (before anyone tells me to downgrade to the 930, the price of the 950 just dropped by almost 50%! and a 950 is within $20 of the 930 now...)
As a newbie to OC, I understand many of the concepts, and know others who have taken their 930 to 3.5ghz without any issues, so I am setting my initial target to 3.5ghz (I know, that's tame to many of you, but my goal is a moderate speed bump without sacrificing LOW NOISE performance, as I will be using this box in a recording studio.)
My ram needs are insane and expensive. I need 12gb now with an eye on taking it to 24 as soon as my needs or cash allows (which ever comes first). Yes i really need 12/24 for sound library hosting. I have libraries such as VSL which can easily use 3-5gb of ram per instrument family. I am currently running 2 servers of 3gb each, and both are at capacity. I will be replacing both with this new build.
SO -- I have a couple of newbie questions that I am not clear about:
1. Ram speed. Since my plan is to OC the i7 950 to 3.5, is ram speed critical here? I know someone who OC'd a 930 to 3.5, and he has DDR3 1333 (PC3 10666). IS THERE a reason why I should invest in faster ram for the 950 (oc'd to 3.5) ? Do I NEED DDR3 1600 (PC3 12800) or even faster?
2. What happens if I buy ram based on an optimal OC speed, but then elect to go back to the i7 default - will the faster ram still be ok?
3. If I choose to "only" install 12gb now (3x 4gb) to conserve cash, then add 12GB more later on, any considerations?
4. is cas latency mission critical? -- do you really only get what you pay for?
5. Any suggestions as to brand and part # of 3x 4gb kit that has good bang for the buck, and a speed that is appropriate for the i7 950 @# 3,5ghz ?
6. What's the reason that OCing with 6 ram slots filled is trickier than with only 3?
THANKS for reading this and any help you can toss my way. I hope to share with others soon.
Thanks.
J
1: 1333mhz will get you a 3.5ghz overclock easy, 1600mhz for 4ghz, 1800hmz for 4.5ghz, and 2000mhz for 4.6+ghz.
2: the board will just default back to the stock speed supported by the X58 chipset (1066mhz)
3: that will be fine, just make sure the board supports 24GB ram in bios, as alot of boards only support 16GB
4: dont get DDR3 with a latancy higher than 9-9-9-24-74
5: any G.Skill, Corsair, OCZ ram is good.
6: this is because the voltage needed from the CPU VTT is higher to support the 3 extra sticks (more heat)
Thanks for helping out a newbie. The more I read the more confidence I have to dig deeper. Thanks to everyone for sharing their expertise.
1 - 3 of 3 Posts
