I know they are not top of the line. I have used them in budget builds for others. A couple of those over a year ago. Not a single issue. I will say I usually only use those when ppl bring me oem tower with a bad psu. That cx is much better than what hp and dell use most of the time.Originally Posted by Yukla
Wouldn't buy it for $5. It's a problem waiting to happen - a ticking time-bomb.
People should know better than to cheap out on the power supplies of their PCs. Yeah the CX line doesn't blow up (most of the time) but it doesn't exactly last very long and is very cheap because it is very cheap.
Thanks for sharing anyways
how do you get this value?Originally Posted by AlphaC
This is going to be one of the better PSUs you can buy for < $30 , however it only has ~ 380W on +12V.
The biggest reason is Corsair warranty.
Price is only one part of the equation though, for $50-60 you can usually get something much better like the Rosewill Capstone 450 or 550 or XFX XFX TS 550W.
It's an excellent PSU for the price. My CX400W is still chugging after 5 years on a C2Q/8800GTS rig. No problems whatsoever.Originally Posted by Yukla
again, the CX series is a good (great actually) PSU for a BASIC BUDGET build.
Yap, it's designed for a family budget PC or HTPC. And it is a lot better than the "Fire hazards" that come free with the case (which most budget builds consist of).
np. At $20. I grabbed one for a backup. I do builds for ppl at work and many of them want htpc type setups. These have worked great fo me in 4-5 installs. I never had one crap out. Then again I never tried overvolting gpus or bios moding cpus on such a unit and I dnt suggest it.
Aye, it may not be the best PSU in the world but this cannot be beaten for the price. Most stuff that costs $20 is just a hazard, this isn't.
