[newegg] razer 5.1 headset $69.99
426 Views 4 Replies 5 Participants Last post by  Sonorously
http://www.newegg.com/special/shells..._-ShellShocker
the shell shocker so only a limited supply.
1 - 5 of 5 Posts
I had these headphones. They were not bad at all. I think they are worth the price as they also have a microphone and inline volume.
The adapter is weird unless you own the Razer sound card though.
not to kill the thread or anything.. but i would also avoid them. i bought them for like 55 from woot.com within only days the paint on the metal frame started to wear away. then eventually the metal frame cracked, (and then started to crumble where it cracked in half) then finally two of the speakers in the left ear died.. all within i think 6 months max?
although! sound was fairly good! but quality is low..
im using these now, they are just as good basically, maybe 1-2% less quality sound wise than the hp-1 but alot less cost and they haven't broke yet!
The paint wears off a bit, but the headphone shouldn't fall apart so easily. I've had mine for roughly 6 months as well with heavy usage and rough care and they're still going strong. The paint has chipped off a bit, but they're still perfectly fine.
Maybe your head is too big.
1 - 5 of 5 Posts
