1 - 5 of 5 Posts
Hi,
1. What I would like to know is if there is a driver available for this kit or a soft for configuring the mouse???
2. When I press the right button once it makes a stronger noise than usual, then it sounds normal. I let it for a few seconds and when I press it again it makes again the same loud noise and returns to normal. Is this normal or the mouse is broken?
I've just bought the kit. It's new.
Thanks and please a good advice will be appreciated.
The kit looks like this:
Googled and more for this brand. Looks like it just going to install generic drivers.
And yes the sound you hear is normal.
Imagine that is a stiff spring. and needs some break in for the noise to go away.
1 - 5 of 5 Posts
