1 - 19 of 19 Posts
Sorry guys but i am not updated there's a new beta bios for my motherboard and the description says
"Enable support for Next Gen 22nm Processor."...
22nm?what is this a new cpu's?can anyone explain more please about 22nm?
thanks!
Storage Nut
Next die shrink to intel Ivy bridge cpu's More efficiency and performance with less heat.
Storage Nut
Originally Posted by someonewhy
and when does it comes out?
Not sure...nest year, I think the mobile cpus come out in the beginning/middle of the year and the desktop variants come out near the end...not sure though.
Super Moderator
^This
And I read somewhere on the internet that they are released in Dec 2011 but don't take my word for it. It is probably just a rumour, I also don't know where I read that from right now I might remember later.
Storage Nut
desktop variants?
Non laptop models lol
Snadybridge-e is coming out nov 15 btw. I doubt Ivy bridge will come out a month later.
Storage Nut
oh yea i was thinking about the e version too...its 22nm too?and there's a big difference between the e version and 2600k?
Nope they will be 32nm
The difference b/w the non -e and the -e will be price...it will be like the x58 to p55 setups.
Storage Nut
oh really?what's the price?
I heard it will be like the 500+ for cpu's, but we will find out soon. It will probably be like the previous i7 series. The mobo's and ram will cost you more too.
Discussion Starter · #13 ·
so your saying if i want to move to E versions i gotta switch my mb and the ram too?and do you have a link for them that explain more?i remember there was a website dat says all the infomration and the prices.
Expect the highest end processor to be $999, as is usual with every generation.
Storage Nut
It will be the 2011 socket not 1155, they support higher ram speeds, 4 and 8 slot mobos. You wont have to switch ram though. Ill look for links...you could use the search on ocn though.
Storage Nut
Don't worry yourself about SB-E and the 2011 socket, it'll be a niche market anyway and will probably have a shorter lifespan than X58. Best advice i could give is stick with 1155 and simply pop in Ivybridge when it arrives and if you need it.
Dude your already running a 2600K, theres no need for you to change anything really, not unless you really really need more cores.
If i where you i'd just leave it until 22nm Haswell arrives.
1 - 19 of 19 Posts
