1 - 3 of 3 Posts
Is it just me or NFSC doesn't have a 1680x1050 resolution. The highest I have is 1600x1200. But the problem is, I have a WS monitor and when I set it to 1600x1200 the car looks fine but since my resolution is 1680x1050 part of it [speed meter, etc] is off the monitor. When i set it to lower resolutions I can see it but my car is completely stretched and looks funky<img alt="" class="inlineimg" src="/images/smilies/redface.gif" style="border:0px solid;" title="Embarrassment"> Is there a way to add 1680x1050?
it depends on how the game is built, in EVE online for example you can add AA manually with a line of code in one of the .ini file. The problem is that this is an EA game so i doubt that will be the case. Your best bet is probably to look for a mod, or maybe send EA an email asking if there is anything to help widescreen view better. I have never played this particular game on a WS though, are you sure there is no in game setting?
<tr>
<div>
Originally Posted by <strong>dannyyboii</strong>
<a href="showthread.php?s=92c472ab6416178eb1b53b0d775857c3&p=1401277#post1401277" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Is it just me or NFSC doesn't have a 1680x1050 resolution. The highest I have is 1600x1200. But the problem is, I have a WS monitor and when I set it to 1600x1200 the car looks fine but since my resolution is 1680x1050 part of it [speed meter, etc] is off the monitor. When i set it to lower resolutions I can see it but my car is completely stretched and looks funky<img src="/images/smilies/redface.gif" border="0" alt="" title="Embarrassment" class="inlineimg" /> Is there a way to add 1680x1050?</div>
</td>
</tr>
</table>
</div><br />
check around google, I have been wondering the same thing. And why EA didn't support widescreen natively gets me. Also check on the wide screen gaming forum, your likely to find something there.
1 - 3 of 3 Posts
