1 - 3 of 3 Posts
Hi,<br>
I just bought Nhl07 for pc and i wan to configure my settings with my controller.<br>
I have the xbox 360 one and i don t know what the settings are.<br>
So can someone help saying me in an xbox 360 controller what is 1,2,3,etc....<br><br><br>
Thanks and sorry for my bad english
I think you might have problems config'ing the controller. For some reason, the control configuration doesn't seem to stick with this game.<br><br>
I am using a Thrustmaster Firestorm Dual, and it works fine, except that the left joystick doesn't do squat. I have to play with the D-pad, and flip the Select button on and off to do things like change lines, etc. It's annoying, but you can get used to it pretty quick.<br><br>
I think you'll want to reset the controls for shoot, pass and hit. Otherwise, leave them as is.<br><br>
Depends on your controller I suppose.
1 - 3 of 3 Posts
