Nibitor 4.9 How do i Use it???
2771 Views 9 Replies 4 Participants Last post by  Photographer
So im new to this GPu Bios editing thing how do i get Nibitor to read all the stuff about my card cuz i cant do anything. I have a GTX260 55nm and 182.06 version driver.
1 - 10 of 10 Posts
Help me anyone!
You need to create an image of your BIOS before you can do anything.
and how do i do that. come one man i said im new to this i have no clue what your talking about.
I've already messed with Nibitor on my 55nm 260, it doesn't give you the option to up the voltage as it is already maxed, it may be possible by messing with the voltage table editor but i'm a Nibitor nub too.
Also, it wouldn't read my bios so you have to save your bios with GPUZ, click the little chip thing under the nvidia logo in GPUZ to save it, then open that file with Nibitor.
Okay, right. You need to download something called nvflash
once you have that, you need to create a bootable floppy disk
put the files you downloaded onto the disk and boot from it.
when it has loaded up, you need to type this: nvflash -b backup.rom
when you have done, reboot your computer, load windows, navigate to the floppy drive,
open backup.rom with nibitor. Then all the info should come up and you will be able to edit.
well i still have it maybe a bios update that evga will comptuer with will allow extra volts. cuz the 55nm GTX260 suck at overclocking.
ummm i use bootable USB flash drives. Its already set to bootable too.
Yeah flash drive will work fine mate
Flashing your video BIOS can be a really scary and intimidating process, but done properly it's really not all that scary or dangerous. With the advent of a Windows version of the Nvidia BIOS Flashing tool this process is even easier, so since I've done this about a bajillion and a half times over the years why not write a quick howto for everyone else?
HOW TO: Flash your video card's BIOS in Windows (nVidia)
This how to was written with the G80 boards in mind - specifically the 8800GTS. The procedure is virtually identical with all of the other nVidia boards.
WARNING
Flashing your BIOS can be dangerous whether it's your video card BIOS or motherboard BIOS. If you don't know what you are doing you can render your video card useless, kill your PC, let the dogs out, or cause a rip in the space-time continuum. According to most of the nVidia board partners flashing the BIOS on their cards will VOID THE WARRANTY. I cannot and will not be held responsible if you break your ****. Understand? Comprende? Capiche?
This post explains how to:
* Backup the video BIOS that's on your card.
* Edit the BIOS with NiBiTor
* Flash the new edited BIOS to your card.
You will need:
* Installed operating system: Windows 2000, Windows XP (32-bit or 64-bit), Windows 2003 (32-bit or 64-bit), or Windows Vista (32-bit or 64-bit)
* NVFlash 5.33 for Windows [CLICK TO DOWNLOAD]
* NiBiTor 3.4a (The nVidia BIOS Editor) [CLICK TO DOWNLOAD]
NOTE: The files above are hosted on my personal server, and are meant for the [H]ardForums only.
WindowsVista
WINDOWS VISTA USERS: The Windows version of NVFlash works just fine with Windows Vista, but there are slightly different or additional steps when using NVFlash under this O/S. Mainly, you MUST disable driver signature checking under the 64-bit version of Windows Vista. You do this by rebooting and pressing the F8 key before Windows loads and choosing "Disable Driver Signature Enforcement" from the boot menu.
The additional information for Windows Vista users are highlighted in blue boldfaced print in this how to.
Backing up your card's original BIOS
Before you flash a modified BIOS to your card you should ALWAYS back up your current working BIOS. You never know when or how something could go wrong with your new BIOS and you may need to revert back to your original BIOS version for a variety of reasons. In the context of this how to we need to do this step ANYWAY to save the BIOS for editing in the next step.
WINDOWS VISTA x86-64 (64-bit) USERS: Before going any further you MUST reboot and hit F8 to access the Windows Boot Menu. Use the arrow keys to select "Disable Driver Signing" from the boot menu and press ENTER.
1. First you need to extract the NVFlash archive you downloaded to an empty directory. For this howto we've extracted the files to D:nvflash.
2. Now you need to open a command prompt window. You can do this a number of ways but we will use the "Start" menu. Navigate to the "Command Prompt" icon from the start menu. (Start -> Programs -> Accessories -> Command Prompt) and click it to launch a command prompt window.
WINDOWS VISTA (32 or 64 bit!) USERS: You need to right-click on the Command Prompt icon and select "Run as Administrator"!)
3. Navigate to the directory where you just extracted NVFLASH. In my case it's on my D: drive in a directory called "nvflash" so I would type:
D:
CD NVFLASH
4. Now let us backup the current BIOS by typing and entering:
nvflash.exe --save oldbios.rom
Here's what the results should be similar to:
We just saved our current BIOS to a file named "oldbios.rom".
Editing your BIOS using NiBiTor
Now let's edit the BIOS! We will use an excellent third party tool called NiBiTor (Short for the nVidia BIOS Editor. This advanced tool will allow you to edit MANY aspects of your video card BIOS including clock speeds.
1. Install NiBiTor by launching the NiBiTor installer/extractor you already downloaded.
2. Launch NiBiTor from the directory it was extracted to.
3. Now to go the File menu and select "Open". Navigate to and select the BIOS file you saved earlier. In our case it's "oldbios.rom" in D:nvflash.
4. Now the BIOS file (oldbios.rom in our case) has been loaded into NiBiTor and is ready for editing.
Here is what our NiBiTor looks like once we have loaded our BIOS:
From this point you can edit the BIOS a variety of ways, and consequentially SCREW UP YOUR BIOS if you don't know what you are doing. So BE CAREFUL.
For the purposes of this howto we are going to do what the majority of you want to do, and that's overclock your card via the BIOS.
5. So let's overclock our card, permanently.
I happen to know the limits of my 8800GTS 640MB, and I know that it can comfortably handle a core speed of 580mhz, a shader clock of 1400mhz, and a memory speed of 850mhz (1700mhz ddr). So next to "3D" I am going to change the speeds accordingly:
(My 8800GTS is actually capable of MUCH higher clocks all around, but I like to play it somewhat safe especially for this howto - nearly all 8800GTS should be able to reach these speeds without extra cooling)
6. Now let's save our BIOS with the new clock speeds! Go to File -> Save BIOS... and save your BIOS to the same directory that your copy of NVFLASH is. Save it with the filename "newvbios.rom".
NiBiTor will pop up a little window saying "File saved" to let you know the file was saved sucessfully. Now you can close NiBiTor!
So at this point we've backed up our current BIOS, and edited it for BIOS level overclocking. You can do a LOT more with NiBiTor and we will discuss that in the second post in this thread, but for now you can find information on more of the advanced options you can change using NiBiTor by visiting the NiBiTor Guide over at Mvktech.net.[/size]
Flashing your card with a new BIOS
1. Open a command prompt window. You can do this a number of ways but we will use the "Start" menu. Navigate to the "Command Prompt" icon from the start menu. (Start -> Programs -> Accessories -> Command Prompt) and click it to launch a command prompt window.
2. Navigate to the directory where you extracted NVFLASH earlier. In my case it's on my D: drive in a directory called "nvflash" so I would type:
D:
CD NVFLASH
3. Now comes the fun and dangerous part! Let's use NVFlash.exe to flash our 8800GTS with the new BIOS file we just made in NiBiTor! You do this by typing "nvflash.exe newbios.rom". The flashing tool will examine the BIOS file and then ask you to confirm by pressing the Y key - you can also CANCEL at this point by pressing N.
Once you press Y there is NO TURNING BACK. The flashing tool will begin reprogramming the EEPROM on your card with the new BIOS. During this process you should NOT try to interrupt it in any way. It will take around 20 to 30 seconds to complete. Once the flashing procedure has completed you will see "Update Successful.".
Example:
4. Your card has now been flashed with the new edited BIOS. You should close the Command Prompt window and all other open windows, and restart your PC via the Start menu shut down or restart options.
So let's reboot and check the nVidia nTune panel to see what it shows our default clock speeds as:
Well how about that?
So there you have it! No more messing with third party applications to overclock a card you know is stable at a certain speed. It's a great method when you like a clean system.
source = http://www.hardforum.com/showthread.php?t=1199078
1 - 10 of 10 Posts
