I would go with the D5000 despite the recall issues. The D5000 has video capability and the articulating screen.
Nikon's D5000 is the next model up in the range, and while both it and the D3000 share the same AF system, on-demand viewfinder grid lines and DX 18-55mm VR kit lens, there are many key differences. Most notably, the D5000 features Nikon's 12.3 Megapixel CMOS sensor, widely used across its range including the D90 and D300s. Not only does this sensor deliver two extra Megapixels and some of the cleanest, noise-free images in its class, it also equips the D5000 (and the D90 and D300s) with Live View and an HD Movie Mode. The D5000 may have a slightly smaller 2.7in screen, but it's fully articulated, allowing you to easily compose at unusual angles in Live View - and advantage it also has over the D90 and D300s, although those models boast higher resolution VGA screens. Continuous shooting on the D5000 is also one third quicker than the D3000 at 4fps. In its favour, the D3000 has a slightly larger 3in screen (fixed in position, but then without Live View, it doesn't matter), the new easy-to-use Guide mode, and is of course cheaper. But the D5000 already has a very capable help system, and if your budget can stretch it simply offers a lot more features for the money, including 2009's key features of Live View and HD Movies. See our Nikon D5000 review for more details. Source: http://www.cameralabs.com/reviews/Ni.../verdict.shtml |
