1 - 7 of 7 Posts
i just bought 2 delta fans of ebay..now tht i check the description it says comes withut conectors!!! *** is dat sposed to mean ?
it doesnt come with molex connectors at the ends, so u have to twist on or solder your own. u can choose if u want 3 or 4 pin that way.
!!!!!!!i cant solder!!!!!!!!!!!! were can i get the conectors and whats better 4-pin or 3-pin?
u dont have to solder em, u can just twist them together. all u need is a couple old fans or cables ure not using, and cut em off and twist em together. 4 pins are molex, 3 lin are the ones that like plug into the mobo. but u want to plug into psu, because those are powerful fasn with high wattage demands
if u dont have em, u can probly get them at your local computer store for like 50cents
lok up^
o ok...dam me i never read...i go buy fans with no connecors lol o well easy to fix prob
1 - 7 of 7 Posts
