1 - 2 of 2 Posts
i have a GB radeon HD 7950...its stock clock was 1000/1250mhz
But usualy in some games it lags so i OCed to 1050mhz core clock frm 1000 and left memory clock untouched cause increasin tht caused a grey screen..so the clock was gud..no crashes in games..so i decided to increase 1 more..so oced to 1075mhz..but starting nfs rivals and after startin to drive.Game froze and blue screen came..so this time i tried to up the voltage..stock was 1.056v and i increased to 1.061...nfs rivals worked nicely for 15-20min..temp was around 70-75 degrees..but after 15min game froze again..bsod and when it auto rebooted..i heard the beep but no display on screen .all fans was spinning tho..help?
Watercooler
The 7950 has 2 Bioses yes? Try and use the 2nd Bios on the card. I would try and disconnect GPU and reconnect it, try and boot with onboard gpu and see if you can get into windows also.
1 - 2 of 2 Posts
