Ok,
Because the VS208 Monitor is only a VGA cable for it so I have to use a DVI adapter because there isnt a VGA port on graphics card. if that makes sense.
Only got a vga cable for it so i use a vga to dvi adapter.
Once again maybe you dont understand or dont know how to fix this..
The monitors work everything works im on the pc now chatting to u, this whole msg would take 30 min to type on phone and then correct.
SOOO....
They work fine They jus dont get detected when its booted, UNLESS I GOTO BIOS. then to The Drives list and select the ssd.
