I've been using dual 7900GTX 512MB in SLI for a while now but only recently notice this after install some program to monitor frame rates while gaming... that my frame rates per second is the same while in single mode nor in SLI mode.
First, I switched between single mode and SLI in the 3D setting from NVIDIA Control Panel... noticed no different in performance
Then, I took off a card physically... then switched the card to see if they are both working properly ... then SLI but PFS on all 3 scenarios are the same I got 64 fps in World of Warcraft... no increase in performance whatsoever.
And yes... I know how to enable SLI in the expert board... if not it wont even confirm that I'm in SLI mode. I already checked on that.
Can someone tell me whats happening here?? I'd really appreciate.. Thx in advance
