Install the latest drivers for the video card. Run a directx dialog to test them. I believe it needs that 8-pin power connector.
Originally Posted by McDown ![]() I think 380W PSU is too weak for your build. I had the similar problem a while ago when I upgraded to Athlon X2 with the same power supply. You need more juice ![]() |
Originally Posted by xandypx ![]() from any number of websites... this is the type of plug you need: although you may find it less expensive elsewhere. http://pcpartscollection.stores.yaho...suto8atxm.html but you would be better off getting a different power supply with the ATX 2.2 EPS 8 pin connector on the PSU utilizing the molex adapter, all of your power for everything comes off the +12V2 Rail rather than the +12V1 rail which is dedicated to the CPU EDIT: A quick glance at the manual for the Mobo, shows an independant 4 pin Molex on the borad to supply power to the graphics card. The connector is labeled: JATXPWR3: Auxiliary Power for Graphics, and is a standard molex 4 pin connector... does plugging this in help? the manual also shows the 8pin JATXPWR2: ATX Power Source Connector as only the CPU power. so theoretically, a single 4 pin connector should provide adequate power to your AMD 2400be CPU... it's only a 45W core |
