1 - 5 of 5 Posts
Absolutely no power to the system at all (fans, lights, etc). System lost power after running for some time. The MB is a M7VIG400 COMBO with a AMD SEMPRON processor and the chipset is a VIA KM266 Pro+ VT8235. Cleared CMOS, checked power connectors, etc. Any ideas how to restore power to system?
Sounds like a crappedout PSU, and it might have taken some of your computer stuff with it.
I would try a different psu if you can, also check that the ATX connector is properly pluged into the mobo, unplug the PSU from the wall for a few mins and plug it back in. Take out the cmos battery for a few mins and put it back in..
Just some suggestions.
He's dead Jim.
Do you hear a sickening pop sound when the computer loses power?
Your PSU might be dead
If the electrical burning smell from your PSU exceeds that from the elecrical burning smell from a motherboard pile that has caught on fire
If you randomly loose power to your computer
Your PSU might be dead.
Seriously though, when your computer shuts off does it make a popping noise?
1 - 5 of 5 Posts
