1 - 14 of 14 Posts
i have had to put a new motherboard in one of friends pc's, but the only thinkg is that when i go to power up i get a short burst of power and then within 1 seconds it cuts out, this will happen everytime i press the power button, but i cant get it too power up fully. is there anything i can do?
Sounds like the psu isn't powerful enough. Have you tried booting with only the bare minimum installed?
the very bare minimum is installed, psu is powerful enough as it is the same as my psu, but there is less components in the system
Q Tecs tend not to have the best reputation. What else is in the system?
Discussion Starter #6
ok i have just tried another psu and still the same problem this is weird
edit:it wouldnt be anthin to do with the wire coming from the plug socket in the wall would it? hmm ill try that now
Have you got the front panel connectors correctly wired up to the motherboard?
well i only need the power button, reset switch and speaker in dont i?
Are they on the correct pins on the mobo?
so you guys got any more ideas
Try switching the ram around or using just one stick in different slots. Also make sure everything is connected and seated correctly.
1 - 14 of 14 Posts
