1 - 3 of 3 Posts
· Banned
so i bought CM blademasters for the awesome up to 4 static pressure and now i see chassis fan connector and no 3 pin to attach to my fan controller
thoughts? new fans? stock xspc fans on the rad? what would you do?
if i hook them to the molex and straight to psu what speed would they run? if i set them on sys fans on mobo could i just get away with adjusting speeds via a program or something?
i just need the pc running and need a temp solution before i can perm fix this issue
· Banned
they have the 4 pin connectors for the mobo only
the only adaptors i have convert 3pin to the ones that will go to power supply
guess im just going to ghetto water cool untill i can order some new fans....i figured cm blademasters were pwn but thats what happen when you rush stuff
almost as bad as me buying $20 mayhem dye that "FAIL"'s their test on the wiki and then the website doesnt recommend them with primochill tubing but i trusted some guy that posted and it only cost me money since i didnt research
1 - 3 of 3 Posts
