1 - 4 of 4 Posts
Originally Posted by LoNeLyKiLLeR View Post
Hey guys i just build a new pc. The m/b has not onboard graphics card and i want to install windows but i don't have signal from the gfx. Can you please help me? I reset the cmos nothing happens. I plug the monitor with vga/dvi/hdmi nothing works. Can you please help me ?
happened to me last week, turned out my pci-e slot went bad. make sure the slot isn't dusty, or if you can try the gpu on another system, do so, to rule out other possible causes.
1 - 4 of 4 Posts
