1 - 20 of 50 Posts
Hey guys, My new Hiper 580W Type-R arrived today and when I hook it all up I get the mother of all errors
"No Signal"
All the fans run (some more powerfull than usual) and windows boots up (because the lan shows up on my mums computer) But the monitor gets new signal
I reseated/checked all the wires. What else could I try
Please Help
Thanks
that happened to me not to long ago..i just took out my video card for a while let it sit on my desk and started up my computer iwth out it in turned it off put it back in and turned it back on and it worked..
but maybe when you took your card out there was some static or something and you killed it? do you have another card to test it with?
Discussion Starter #4
No I dont have another card to test it with cause I swapped this X1800GTO for my X800GT.
I go up and try reseating the Card
the only other thing i can thing of then is to try what PROBN4LYFE said and clear your cmos..does anyone you know maybe have an extra card you can borrow to test?
Discussion Starter #7
Tried reseating - No Use
Reset the cmos - No Use
Originally Posted by PROBN4LYFE
Clear NvRAM?
How Do you do that?
I might have to get my X800GT back of my mate, I think the X1800GTO Is dead - it didnt work before so I bought new PSU - Still not working so.......
If it is the mobo that is dead my new DFI Lanparty NF4 Ultra D is arrivin on Thursday so we will find out what it was
Pull it all apart and start again from scratch. You may have missed something in your frustration. I have done crazy things over time like not plugging in the vid cards dual power connectors properly- that could be the issue. Put your old PSU back in and turn it on- what happens? As Probyn mentioned - jumper re-set. Can you get the vid card's fan to run?
Discussion Starter #9
Yeah the fan goes - Strange thing is it goes at 100% and doesnt throtle back to a slower rpm when the system boots - like it usually does with the older PSU(which is a 380 No Name) What Would cause the fan to go at 100%?
If I have to rebuild it I might aswell wait for a few days and use my DFI when it arrives.
Windows definatly boots cause I can use hotkey to open winamp and start playing music
This may be useful, this worked for me.
Take out all components but the bare minimum.
(PSU, 1 stick of ram, CPU+HS, HD, graphics unless onboard)
Also take out the power cord for the moment.
Take the cmos battery out of the machine for atleast 5 minutes. After the 5 minutes put the battery back in along with the power cord and boot. If a successfull boot, add the other components back into the machine and reboot.
Discussion Starter #11
I Tried that already - No Luck
Arghhh I hate No Signal
Im just going to have to wait till I get the new motherboard on thursday I think and rebuild it again
Lan simply shows your network connection...nothing to do with your OS
I doubt that your system is even getting past POST, let alone windows booting up!
Do you hear a series of beep codes when you power up? This can sometimes be your only clue as to what may be wrong when your monitor receives no signal.
Do you take precautions against ESD when you touch componentry inside your system, and lastly, have you checked and double checked all your device power connections and the ATX to your mobo?
Regards.....
Discussion Starter #13
Regards.....
No beep codes - And yes I used a anti static wrist band and yes I checked all device connections
There is something very wrong with your rig and I suppose it's either the monitor or the VID card. I had my rig a few years ago working without a monitor 'cause it was broken, I just put it in and out of hibernaton with the winamp on to listen to music. It just seems your rig runs without a monitor... weird
Here's something to think of.
*EDIT If the VID card was dead would it still boot? I suppose not... Could you check if the cables that go in the monitor are properly atached?
Discussion Starter #15
Not the monitor as I tried it with my mums monitor - no luck
I dont think it is completly dead - I Have a feelin it may be the motherboard as a couple of years ago I had a working motherboard, took it out case to put in new power supply, put motherboard back and (must have damaged it in some way when I put it back in) and same thing happened, went to maplin got this CRAPPY motherboard took it back, plugged it in, everything worked fine - So I will just have to wait till DFI Lanparty comes on Thursday
Try all output connections on your card along with a different monitor. You have to be unlucky to have killed the card via static. Swap some of the Molex connectors around. Some power supplies need load across the entire supply, all of the 12 V rails so just connect the spare molex plugs to anything or each other if need be.
Discussion Starter #18
Well, I had to try. Hope it works out.
Thanks for trying
I will keep you guys posted when DFI Gets here. Just look for a thread called "WOoooooooOooooOoooooooo It Works" or "I Have no comp - I threw it out the window"
Thanks again
my friend has had this problem, it was his CPU he found out in the end, if you can find a way to test out the CPU, i would do that, thats the only thing i can think of at the minute.
1 - 20 of 50 Posts
