1 - 3 of 3 Posts
OK, I posted this in another section, but I thought you guys might be able to make better of it. I turn the PC on, and it boots fine, and the Windows start up screen shows. But when the Welcome screen should appear, my monitor declares no signal. The startup sounds still work, and the PC recognises when I insert a DVI cable, so is it a problem with my GTX?
1 - 3 of 3 Posts
