1 - 1 of 1 Posts
Hi, I've been trying to overclock my Radeon HD 2900 Pro for quite a while now, and the problem is that none of the softwares are working. I believe my driver isn't supported by CCC Overdrive, hence there is no overdrive option there. I followed the How To: Overclock Your ATi GPU guide, but Afterburner isn't doing anything. I can change the clock frequency by over 100MHz but the monitor doesn't show a sign of it. The temperature stays constant, too.
I also tried using RivaTuner, but I still have the same problem. I can change the clock frequencies but I get no results. Do you have any suggestions?
1 - 1 of 1 Posts
