1 - 4 of 4 Posts
Hi,<br><br>
I have a Sony Vaio K215B, for the past week i've had no sound on my laptop.<br><br>
Well, there is sound but it's very very quiet, so i turned up the volume in the "Sound and Audio Device" Tab in the Control PAnel and it's slightly better now but it's no where near how loud it used to be.<br><br>
Does anyone have any idea's?<br><br>
Thanks
Did you install any programs, drivers, or change anything in the last week when it went out?
Yup, Perhaps re-install the drivers for the sound...?
Administrator
Make sure you have installed the most up to date drivers after removing the previous sound drivers.<br><br>
After this go into Each sound control panel and make sure that the Audio output volumn is at max.<br><br>
Also not to sound silly but if you are using external speakers make sure the Audio jack is in the laptop all the way.
1 - 4 of 4 Posts
