I want to replace my stock Xigmatek CPU cooler fan.
http://www.xigmatek.com/product.php?...&type=overview
the fan needs to be 92mm and I want something that is (in order of preference):
A) less dba
B) better build quality
C) close in CFMs
The Xig stock fan is a 92mm 2800RPM, 28 dba, 52CFM.
Ive narrowed it down to:
1) Noctua NF-B9 $16.99
http://ncix.com/products/index.php?sku=28452
1600RPM, 17.6 dba, 37.8CFM
2)Scythe S-FLEX SFF92C $12.45
http://ncix.com/products/?sku=38013&...facture=Scythe
2000RPM, 25.3 dba, 43.2 CFM
Of the two, which one should I go with? or is there a better option for me.
Also, will I be loosing THAT MUCH performance going from 52 CFM to 37-43? That is if the Xig stock actually moves 52 CFM.
A) less dba
C) close in CFMs
