Noctua NF-R8 PWM Case Fan
Description:
The classic NF-R8 80mm fan helped to found Noctua's reputation as a top-tier manufacturer of premium quality quiet cooling components and still impresses users with its exquisite quietness and superb performance. The new PWM version features Noctua's novel, custom designed PWM IC for fully automatic control and ultra-low power consumption. Equipped with Noctua's signature SSO bearing and topped off with a 6 years manufacturer's warranty, the NF-R8 PWM is a proven premium choice for the highest demands.
Details:
Description:
Details:
Detail | Value |
Binding | Personal Computers |
Brand | noctua |
EAN | 0842431014078 |
Feature | Proven NF-R8 Design. Tens of thousands of quiet cooling enthusiasts swear by Noctua?s classic NF-R8. Its impressive quietness, excellent performance and impeccable, time-tested quality made the R8 a default choice for 80mm quiet cooling. Supporting fully automatic PWM speed control, the NF-R8 PWM uses Noctua?s novel, custom designed NE-FD1 PWM IC that integrates Smooth Commutation Drive (SCD) technology. The NF-R8 PWM is supplied with a Low-Noise Adaptor (L.N.A.) that reduces the maximum fan speed from 1800 to 1300rpm. The L.N.A can be used either to run the fan at a fixed speed of 1300rpm or to cap the maximum speed when using automatic PWM control. Extensive Cabling Options that are fully sleeved and a 4-pin y-cable allows to connect a second NF-R8 fan to the same PWM fan header for automatic control. Combining the proven concept of hydrodynamic bearing w/ an add'l magnet tht supports the self-stabilisation of the rotor axis, Noctua?s time-tested SSO-Bearing tech. has become synonymous w/ supremely quiet operation & exceptional long-term stability. Size: 80x80x25 mm. Connector: 4-pin PWM. Bearing: SSO. Blade Geometry: Raised Blade Design. Rotational Speed (+/- 10%): 1800 RPM. Rotational Speed with L.N.A. (+/- 10%): 1300 RPM. Min. Rotational Speed (PWM): 300 RPM. Airflow: 53,3 m³/h. Airflow with L.N.A.: 39,4 m³/h. Acoustical Noise: 17,1 dB(A). Acoustical Noise with L.N.A.: 10,2 dB(A). Static Pressure: 1,41 mm H2O. Static Pressure with L.N.A.: 0,74 mm H2O. Max. Input Power: 0,72 W. Max. Input Current: 0,06 A. Voltage: 12 V. MTBF: > 150.000 h. Scope of Delivery Low-Noise Adapter (L.N.A.): 4-Pin Y-Cable,30cm Extension Cable,4 Vibration-Compensators,4 Fan Screws |
Label | Noctua |
Manufacturer | Noctua |
Model | NF-R8 PWM |
MPN | NF-R8 PWM |
Publisher | Noctua |
SKU | CAAmzCompAcces15129 |
Studio | Noctua |
Title | Noctua NF-R8 PWM Cooling Fan |
UPC | 842431014078 |
Warranty | 6 |
CatalogNumberList - CatalogNumberListElement | NF-R8 PWM |
Item Height | 3.15 inches |
Item Length | 3.15 inches |
Item Width | 1 inches |
Package Height | 1.3 inches |
Package Length | 8 inches |
Package Weight | 0.45 pounds |
Package Width | 6 inches |
PackageQuantity | 1 |
PartNumber | NF-R8 PWM |
ProductGroup | Personal Computer |
ProductTypeName | COMPUTER_COOLING_DEVICE |
UPCList - UPCListElement | 842431014078 |
Item Weight | 0.4 pounds |
