1 - 6 of 6 Posts
With this set up will I have to stick with a low profile like the Corsair Venegeane LP? On a build with a different motherboard I was told I had to use LP memory when using the Noctua NH-D14. Thanks.
I just installed some Corsair Dominator Platinum under a Noctua NH-D14 on a Maximus V Extreme (which I guess should be quite similar to Formula) by just cutting 3 blades of the first heatsink with a Dremel so the task can be achieved easily. I don't think that performance may degrade anything noticeably.
On my mobo it covers first two slots.
Here's the result:
Discussion Starter · #6 ·
Has anyone tried taking apart the noctua fans to paint them. I am amazed that a company could come up with such an ugly color scheme for fans.
Also is the phanteks cooler the same size and only takes low profile memory? Thanks
1 - 6 of 6 Posts
