MikeVall, I think you are spot on with your assumption. I chose the H50 because for the extra couple of degrees I sacrifice I get a clean looking case and don't have a 1kg cooler hanging off my M/B
Whats wrong with your Frio, the NH didnt beat it by that much in the reviews. I'de stick with what you have and not spend another $90 for only 3-8 degrees C less if even that much, thats a little ridiculous dont you think?
Oh and if you dont mind the noise, use those mean suckers off your frio if you do get either one. lol that would at least make temps lower than using some 65cfm fans. 101cfm with 4.22mm H2O static pressure could be helpful.
Personally like my H50 and would go with the H70, but I got my H50 for cheap and had my own fans. Oh and I don't like having a brick hanging from my motherboard.
1 - 20 of 58 Posts
