Noctua NH-U12P + Ultra Kraze
328 Views 3 Replies 2 Participants Last post by  AUS.R34P3R
Hi all,
I have the NH-U12P and 5 Ultra Krazes lol, oh plus a 256CFM Delta (yeah, not using that). Anyway, those that have this CPU cooler, and have Ultra Krazes attached, could you please show me some close up pictures of how you attached the fans to it? Having some troubles, I'd like to see some of your setups. Thanks!!
1 - 4 of 4 Posts
I have the NH-C12P and all fans go on the same.
Just hook the clips through the body of the HSF, then pop the protrusions of the clips into the holes.
As the clips only go through the first set of holes, it doesn't matter if it's a 25 or 38mm fan, they all fit.
On another note, if and when you do push/pull, remember to have the fans pointing the same way.
thanks heaps AUS! you da man!
No problem mate, all the best with your cooling.
1 - 4 of 4 Posts
